fyl
Member Since 01 Dec 2012
Offline Last Active Jun 17 2015 09:15 AM
#300775 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by fyl on 30 October 2013 - 02:30 AM
Is it possible to enable DDS on a S-Max or do they need sensors in the tyres unlike the Focus/Kuga?
Also to enable auto locking for a Mondeo/S-max is the procedure as follows :-
- Read from IPC
- Read from BCM
- Select Central Configuration
- Automatic Locking by speed - Select with automatic locking
- Write to IPC
- Write to BMC
Is that correct?
Or should it be done the following way?
- Read from BCM
- Write to BCM
Then
- Read from IPC
- Write to IPC
Ben
Not sure about the S-Max but I enabled DDS on my focus mk2.5 without any sensors in the wheel as DDS uses the ABS sensors (guessing Yaw/Pitch/wheel speed) to work. I had a recent flat and DDS issues a warning on the information cluster to check tyre pressure.
#265023 Guide Fitting Cruise Control Focus Mk2 & Mk2.5 And Ford C-Max
Posted by fyl on 03 June 2013 - 04:44 PM
Thats the wrong connector. Try the one in the passenger footwell lol
:huh:  :D
