Member Since 03 Dec 2012
Offline Last Active Feb 15 2013 09:28 PM
Brakes Problem
15 February 2013 - 11:20 AM
Hi I have a 2006 lx tdci mondeo
Problem is my brake pedal has a lot of travel I have put pads and discs on front and pads on the back
I have bled the brakes so no air in there but I have found the front passenger side brake is slow to react when the pedal is pressed
So could this be the caliper or the brake line
And help would be great
Thanks a lot
Dot 4 Or Super Dot 4 That Is The Question?
13 February 2013 - 10:13 PM
hi all
i want to replace my brake fluid in my 2006 mondeo lx tdci
but not sure which one to use
dot 4 or super dot 4 there are many types
can any one tell me please
i want to change it as it is a bit spongy
thanks a lot
Heated Front Windscreen
22 January 2013 - 06:29 PM
hi all
i have a 06 reg 2.0 tdci lx 115 mondeo
my problem is heated front windscreen it does work lol
the light will come on but on for about 20 seconds and go off
i have taken out the relay and put a wire in there and the screen works the light on the switch comes on and it works no problem i have brought a new relay
i have no blown fuses
i have got error code from the gem b2256 front windscreen heater relay short to ground
i need a ford wire diagram for the heated screen with ground placements if any one can give them to me that would be great
any ideas where the problem may be
thanks a lot
Drain The Radiator
14 January 2013 - 07:46 PM
hi all
here is a good one
does any one know how to drain the radiator on a 2006 mondeo lx
i have looked for a drain plug but cant see one no where
so i thought i would take the bottom hose off
my hose has a clip which i have popped off but how do you get the pipe off i have been told it is a twist
but i have tried this on the top hose as it is better to get to but no way is that coming off
i need to empty the rad because i have put a cleaner through the system as it just had water in it
now i need to get it out and put anti freeze in it
any advise would be great
thanks a lot
Wiring Diagram For 2006 Glow Plugs
11 January 2013 - 07:27 PM
can any body help me find a wiring diagram for the glow plugs as my 60 amp slow blow fuse keeps blowing
glow plugs seem to be ok the glow plug rail is not grounding out so i am a bit stumped relay seems ok
its a strange one lol
thanks a lot
