Member Since 05 Dec 2012
Offline Last Active Apr 30 2014 08:28 PM
#355580 2000 Fiesta - Buying Used And Need Quick Advice On Rust On Door Sills
Posted by BigD on 21 April 2014 - 11:29 AM
#354931 Can't Seem To Accelerate Past 90Mph
Posted by BigD on 19 April 2014 - 11:05 AM
I'm passing a ford garage today you think it's worth taking it in and seeing what they say?
No.  Ford garages employ idiots.
Take it somewhere else.
#354930 Forgive Me Focers For I Have Sinned!
Posted by BigD on 19 April 2014 - 11:03 AM
FFS, changing a wheel should be part of the driving test (or at least, knowing where the spare one is).
#354821 Mondeo Tdi 2005
Posted by BigD on 18 April 2014 - 08:46 PM
What color smoke?
#354337 What Causes Uneven Tyre Wear?
Posted by BigD on 16 April 2014 - 08:34 PM
#354107 Evans Halshaw Guarantee :(
Posted by BigD on 15 April 2014 - 09:28 PM
#353015 Negative Battery Terminal
Posted by BigD on 12 April 2014 - 12:10 PM
The other night I disconnected my battery, then reconnected it a short time later. It turned out I removed the positive cable by accident because it sparked a little when I put it back on.
The negative cable appears to be hidden on the other side of the battery underneath the plastic cowl thingy, so how the hell do you remove it without removing the battery?
Just so you know, you will get this even when reattaching the negative terminal if something in the car is drawing power (like the interior lights, for instance, if you've left one of the doors open).
That aside, I often think that with the way these cars are 'designed', Ford must employ Homer Simpson.  Some of the issues you encounter when working on them are just laughable and it boggles the mind that somebody in that position could ever design a car in such a stupid manner.
#351296 Focus Y Reg Fuse Box Location
Posted by BigD on 06 April 2014 - 11:31 AM
It's behind the glovebox, and the ticking noise will be a relay opening/closing.
Empty the glovebox, then close it up.  Look underneath and you'll find three screws.  Take them all out, then open the glovebox, push the sides inwards and the whole thing will come out.
(You don't HAVE to remove it fully, you can just drop it down without taking the screws out, but for the 60 seconds it takes to do it, you'll get much better access).
Oh, there's an engine bay fusebox too.  If memory serves it's right at the back corner of the engine bay, on the passenger side and nearest the windscreen.
What problem are you having?  What are you hoping to find in there?
#350179 It's Ok, It'll Buff Out.....
Posted by BigD on 02 April 2014 - 09:33 PM
YOU B'SATARD youve cause £3.75 damage to my mazda.HOW VERY DARE YOU.
Improvements, mate.  £3.75 of IMPROVEMENTS.
#350068 Why Bikers Have A Bad Reputation
Posted by BigD on 02 April 2014 - 04:08 PM
#349761 It's Ok, It'll Buff Out.....
Posted by BigD on 01 April 2014 - 03:23 PM
Serves him right.  Complete "showing off" fail.
#349253 Speed Cameras, Some People Deserve A Ticket
Posted by BigD on 31 March 2014 - 01:11 PM
..and I bet you anything when the summons comes through, they'll be posting on their favourite motoring forum complaining about how hard-done-by they are and asking how to get out of paying the fine.  :rolleyes:
#345343 Fan Failure (Continued)
Posted by BigD on 20 March 2014 - 09:59 PM
You said you didn't get any sign of life from the output on the control module, but I'd urge you to recheck this.  When I did mine I noted that there was a signal coming through but only briefly every 30 seconds or so, and only one one of the pins but I can't remember which one.  I don't know the ins and outs of how the system works but the upshot is, that was on a working control module.
And yep, James is correct - I know the fan on my mondeo quite intimately, as I'm on my 4th one in two years.  Got sick of the crappy Ford ones and have a 14" universal fan in there now.  Required a few of the mounts sawing off to get it into the fan chassis (held on with zip ties), and a little light soldering to attach the old fan plug to the bare wires of the new fan, but it works like a charm, and a hell of a lot better than paying Ford nigh on £200 for a new bespoke unit, which only does the same job.
#345125 Rust
Posted by BigD on 20 March 2014 - 03:48 PM
It's not just Fiestas - every Ford has been notorious for rusty arches.
I did the arches on my Focus (and my Escort, and Fiesta) and never used any kind of degreaser.  All I did was rub it down, get a bit lairy with the Kurust, then filler, sand, prime, paint, topcoat.
The problem is the 'lip' at the edge of the wheel arch - it fills up with dirt, which gets/stays wet, and causes rust to eat through from the inside - not helped by the stupid carpet wheel-arch liners used on a lot of Ford which serve little purpose other than to hold even more moisture.  If you have rust on the outside then it will almost certainly come back at some point.  All you can really do (short of replacing the whole panel) is repair it as best you can, then treat the inner wheelarch with Waxoyl to repel water.
#344697 A/c Auto On
Posted by BigD on 19 March 2014 - 11:29 AM
I had a Vauxhall prior to this and you couldn't really hear it.
It was probably broken.  :P
(sorry, couldn't help myself)  :lol:
