new_horizon
Member Since 10 Dec 2012
Offline Last Active Nov 12 2013 09:05 AM
In Topic: 2007 Fiesta 1.6 Diesel Overheating Problem
06 January 2013 - 12:52 PM
Thanks Stef and Diesel. I think it's going to have to be a new waterpump-do you have any idea if this requires the cambelt having to come off?
Your advice has been really appreciated
05 January 2013 - 08:08 PM
Can I ask what might be a slightly naive question? If the waterpump was indeed at fault-would the car not overheat at other speeds? Just throwing it out there as it's only 50 mph +
05 January 2013 - 07:58 PM
I'll check the waterpump for corrosion when I get a second-I wouldn't have thought that at 36k much should be failing at all but I suppose you never know!
The fan is cutting in and out as it should be so we can rule that and the thermostat out...
Ideas are welcome as always as I think I'm going to have to change the waterpump-which is going to be quite costly I'd imagine on labour
04 January 2013 - 11:59 PM
Hmm noticed today that the top radiator hose is hot but the bottom one is stone cold under normal operating temperature. Suggests a circulation issue-blocked radiator or perhaps inefficient water pump?
03 January 2013 - 10:43 PM
Thanks for your reply. How can I check a faulty sensor? I replaced the thermostat and thermostat housing, which I thought would have fixed this issue...
Yeah pretty immediately-I'd say it takes 20 seconds to completely return to normal temperature...
I haven't noticed any water loss and the water is clean. Compression test happening on Monday. I just can't believe a head gasket on a car with so few miles
