Member Since 15 Dec 2012
Offline Last Active May 19 2013 03:02 PM
In Topic: Alternator Failure???
13 April 2013 - 04:57 AM
Hi Ian
Yes it is driving by a belt which also drives the a/c
In Topic: Fault Code P0200 Eac Fail
09 April 2013 - 02:43 PM
Hi Tommy.
Not really an expert here but these are the fault codes I have. Sincerely hopes this help without causing U any more problems :(
Error Description
P0201 through to P0212
Cylinder #1 through Cylinder #12 Injector Circuits.
The comprehensive component monitor (CCM)
monitors the operation of the fuel injector drivers in the PCM. The test fails
when the fuel injector does not operate electrically even though the harness
assembly and fuel injectors test satisfactorily. Faulty fuel injector driver
within the PCM. PID Data Monitor INJ1F-INJ12F fault flags = YES.
Based on the above I would say faulty injector ??? :unsure:
Best of luck
P.S. If U get it sorted will U please reply back on the forum so as to inform us.
In Topic: Creaking Noise From Mk6 Front Passenger Side Wheel / Suspension
04 April 2013 - 10:06 AM
Hi Guys
I just replaced the top mounting and seat on my Fezz Mk 6. Had the same creaking noise. Actually sounds like the wheel is falling out :(
Once replace, problem solved :)
Good luck
In Topic: Turbo`s
17 December 2012 - 06:40 PM
Managed to track down the previous owner and he told me that the turbo was replaced at about 150k.
Thanks for the advice guys.
Regular oil change it will be then.
In Topic: Timing Belt Change Focus Mk3
16 December 2012 - 04:53 PM
I`d agree with Minnis. If in doubt,change it.
The cost implications is just to severe. :(
