Timty
Member Since 16 Dec 2012
Offline Last Active Apr 01 2013 11:29 PM
In Topic: 1.8 Tdci Fuel Filter Seal Advice Please
07 March 2013 - 06:30 PM
Haynes states the seal should go on the filter housing then fit the filter to the lid and screw down onto the seal.
Stoney871,
Thank you for this. I've just discovered I had it assembled incorrectly i.e. element in first, then seal. I can see now how air that would be pulled in past the threads of the filter housing screw cap could be pulled into the filter housing rather than being blocked by the seal!
I've had issues with my car misfiring and eventually losing all power (tick over revs only, no throttle response, turn off and on again and away we go with no problems). Only happens after 70 miles or so of motorway driving only, not happening on secondary road driving. I guess there is a fair vacuum built up at that speed after an hour or so that could pull in the air, even more so as the filter begins to get dirty.
I will monitor same and post back.
In Topic: Egr Valve Cleaners
15 February 2013 - 07:25 PM
Thanks FOCA. My code reader is an Autel Maxiscan MS509. It was highly recommended in 'Car Mechanics' magazine in 2011, that's why I bought it. I wonder did the code reader go faulty while it was connected and cause my 'Engine Malfunction' warning today or did the car generate the warning and in some way or other (voltage spike?) damage the code reader. Major portions of the code reader lcd are missing. That said when the fault occured I was able to discern this from the lcd: U1040 'Lost communication with the Body Control Module' U0001 'High Speed Can Communication Bus' and U2005 'DTC Definition not found' . I still don't know what that last one is for.
I've ordered a Gendan GCR25 off ebay an hour ago, feel 'naked' without a code reader!
You are absolutely correct in what you say about the blanking plate with the hole. I do have a solid one and will try that. However, in fairness, while I got an MIL light today I did not lose power. This is an improvement! Have I got an EGR issue but the restricted plate did not allow the cylinders to 'flood' with inert gas? Who knows! Is there anything worse than an intermittent fault that does not store a code. Is there anything worse than actualy calling to 4 Ford main dealers in the area and not one of them in a position to put the car on a scan unless you book it in, take a morning off, arrange alternative transport etc etc.
I've had a mercedes e270 cdi for 9 months, 3 of which it spent its time in the garage having torque converters replaced! My mate has a '07 Audi A4 2.0tdi that ate its cam followers, cost 1300 euro to repair and is still not right. My work colleague, with a low mileage 2009 1.8 tdci Mondeo just failed the MOT with a smoke figure of 5.5 (limit 1.5). My neighbour's Peugeot HDi has just had a new clutch/dmf fitted. BUT ... my daughter's 1999, 1Litre Petrol Polo with 140,000 miles never gives trouble!! Conclusion - buy a petrol car.
Ok, rant over, the wine is beginning to work now. I think I will suffer it and take the car to the dealer on Wednesday and see what they might find. I'll let you know what happens. Tomorrow I will attempt to go to Dublin again but this time I am much more hopeful of getting there ... because I'm taking the train!!
Tim
15 February 2013 - 03:19 PM
Oh! No!
The latest update. I took the car on a motorway drive today to Dublin. At exactly the same point on the road as on 2 previous events (after 60 miles of steady 65mph) the Engine Malfunction light came on. However, this time, no loss of power. About 20 miles before this I saw the rev counter and speedo drop to zero and immediately go back to where they should be. I was driving with my OBD code reader connected, hoping to catch the error if it happened. Guess what .. when I tried to read it the screen had more or less gone blank, barely readable but I could see it displayed a loss of connection to the ECU!! Between the previous engine malfunction (mis-fire, light on, no power, engine at idle, no response to throttle, turn off turn on all ok again) and this event (no mis-fire, malfunction light on, no loss of power) I have fitted a blanking plate on the EGR (the one with the 10mm hole). I wonder have I proved my theory that the EGR is sticking open? I did the scan using the Reset button on the column and it came up with D900.
That said I tried 4 Ford dealers today to have a scan done and they are all too busy! I have the car booked in for next wednesday. The service manager there suspects an over pressurisation by teh high pressure diesel pump or maybe an injector fault. He says there should really be an OBD code but I've never found one. He will do deeper diagnostics.
In Topic: Focus 1.8 Tdci Misfire
15 February 2013 - 03:13 PM
The latest update. I took the car on a motorway drive today to Dublin. At exactly the same point on the road as on 2 previous events teh Engine Malfunction light came on. However, this time, no loss of power. About 20 miles before this I saw the rev counter and speedo drop to zero and immediately go back to where they should be. I was driving with my OBD code reader connected, hoping to catch the error if it happened. Guess what .. when I tried to read it the screen had more or less gone blank, barely readable but I could see it displayed a loss of connection to the ECU!! Between the previous engine malfunction (mis-fire, light on, no power, engine at idle, no response to throttle, turn off turn on all ok again) and this event (no mis-fire, malfunction light on, no loss of power) I have fitted a blanking plate on the EGR (the one with the 10mm hole). I wonder have I proved my theory that the EGR is sticking open? I did the scan using the Reset button on the column and it came up with D900.
14 February 2013 - 10:29 PM
Well, since I started this post my car flew through its first N.C.T. test (M.O.T. in Britain) with flying colours. The smoke test limit is 1.5 somethings per something or other and mine read 0.6. Today a work colleague's 2009 Mondel 1.8 TDCI failed at 5.5!! That said, I've got to go from Cork to Dublin tomorrow, a 160 mile motorway blast and I'm not confident the car will make it without dying (Misfire, Engine malfunction light on, engine idle rpm only, no throttle response, turn off, turn on and away we go again, no codes stored). I have also fitted the 'sort of blanking' plate i.e. the one with the 10mm hole. Is there anything worse than a car that you have no confidence in getting you from A to B and back again.
Anyway, in reply to Newbie I have little interest in re-mapping it, I'd be delighted if it would just stay running on what Mr. Ford gave it first day! Happy Valentine's Day to all .. and ok ... I wish the same to my '!Removed!' of a TDCI :)
