IINexusII
Member Since 17 Dec 2012
Offline Last Active Yesterday, 01:42 PM
In Topic: Mileage Query
23 May 2013 - 11:14 AM
they dont tend to be very accurate as they will calculate based of your average mpg, if you dont have any leaks then there shouldnt be anything to worry about as long as your getting good mileage
23 May 2013 - 10:31 AM
Yeah just give it a few weeks then and see how it goes, you can also just have a quick look around the fuel lines to make sure there isnt any leaks.. i noticed my mileage was dropping too only to notice one of the diesel return pipes had come off!
23 May 2013 - 10:24 AM
are you still getting good miles per tank? its probably just a calibaration issue and it should sort itself out over time assuming its a new car
In Topic: Mk1 1.8 Tdci V Mk2 1.8 Tdci - (Tappits)
08 May 2013 - 09:48 AM
Check the engine mounts for the knocking issue, and the tapping sound sounds like you need a valve/tappits adjustment?
In Topic: Using Fog Lights As Drl
06 May 2013 - 10:05 PM
alright thanks for the replies guys, ill be fitting one of those phillips or osram DRL kits soon :)
