Randallsfocus
Member Since 23 Dec 2012
Offline Last Active Feb 27 2015 06:47 AM
Egr Valve To Cooler Gasket
08 February 2015 - 10:33 PM
Hi, does anyone know if the metal gasket between EGR valve and EGR cooler has to be fitted a certain way round? It's on a 2.0 tdci. The gasket has a ridge outwards on one side and inwards on the other, but both EGR and EGR cooler are flat. Any ideas?
Many thanks
Dmf Advise
20 November 2014 - 10:05 PM
Hi after some advise on having my dual mass flywheel replaced. The car is a 2009 2.0tdci with just under 70,000 miles. Would you advise having the complete clutch ( cover, plate and bearings) replaced at the same time? The clutch isn't slipping at all, just a lot of knocking.
Many thanks
Fault Code P0490 After Fitting Egr Blanking Plate
27 May 2014 - 07:49 PM
Hi, I fitted a EGR blanking plate on my 2009 2.0tdci over the weekend. I now keep getting the engine light coming on, I've checked the code p0490 EGR control circuit high. Is this normal after fitting a blanking plate?
Many thanks
Diesel Tank Filler Tube
24 May 2014 - 06:10 PM
Hi I took my focus for its MOT today and it failed on a diesel leak around the tank area. I've taken the drivers side rear wheel arch liner off to look at the filler tube/neck. It looks like there is diesel weeping from the pipe connector that goes back into the filler tube.
My questions are, is this the diesel return pipe? Has anyone else had the same thing?
Any advice please many thanks
Escort Xr3I Advice
23 May 2014 - 09:31 PM
Hi I recently bought 1987 xr3i with 101000 miles. I want to give it a service and wanted advice on which and type of oil to use??
Many thanks
