Member Since 26 Dec 2012
Offline Last Active Jan 06 2013 12:03 PM
In Topic: Coolant Leak
06 January 2013 - 11:56 AM
The agent finally found out the issue , there was a black plastic screw that was jointing the radiator with something , that screw was cracked and there was a sponge below the radiator that absorbs the leakages that why there were no any sign of leakage
Thanks you guys
26 December 2012 - 12:43 PM
Hi Soulman ,
i know this is a bit old thread but did you discover the issue in your car , actually i have the same problem , and i went to ford dealer they made a pressure test and they said that everything in the cooling system is OK , so they refilled the radiator water again and told me to test it again and if there is an issue , they should investigate if there is an issue in the engine itself! so actually i think that the dealer guys know nothing about the car and i don't know what to do
