- → Viewing Profile: Posts: mattyr
Support the club!
- Group Members
- Active Posts 4
- Profile Views 112
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
fiesta tdci zetec s 1.6
UK/Ireland Location
Please Select
0
Neutral
User Tools
Friends
mattyr hasn't added any friends yet.
Latest Visitors
In Topic: Help Please Fiesta Zetec S Diesel 2009 Cold Rough Idle
30 December 2012 - 09:50 AM
rough idle problem,hi think i have an injector fault,when cold if i remove plug from injector 2 the engine rough idle doesnt change when i remove plugs from 1,3,4 injector the car idles even worse. so it seems number 2 injectors not working right.....tried this when engines warm and running right and number 2 injector causes misfire like the other injectors if removed....anyone had this fault...and if it is an injector 2 fault can i change the injector for a new one with the same part number....please help
29 December 2012 - 11:04 AM
hi m8 its a diesel.....but may have found the faul think its number two injector removed the plugs off the injectors when the engines cold number 1,3,4 injectors caused the engine tu run worse but there was no change when i removed number 2....if i buy a injector with the same part number and fit it is it easy to recode them or is it a main deal jobTry changing your HT leads/spark plugs, if its still happening possible coil pack? I had that on my 03 plate fiesta
- Privacy Policy
Find content
