the door lock issue is simple its the fob hold the lock button down and then with the lock button held press the unlock button for 5 secs now all doors will unlock when the fob is pressed once unlocking door can be as simple as water in the lock remove top torque screw on side of door nearest driver spray wd40 in a down wards 45 degree angle refit the torque screw and try if its still the same give it 20 mins then try again worked on my mk1
Tried as you said held buttons down and pressed unlock button once and the drivers door didn't unlock pressed it twice the back doors unlock but drivers is still locked.
Find content
Male
