Member Since 28 Dec 2012
Offline Last Active Jan 16 2013 09:16 PM
In Topic: Ford Focus 2009 Front Wipers Not Working
16 January 2013 - 07:40 PM
Hi Lenny,
I have got to the root of the problem. I have water ingress in the BSI ECU which has damaged the pcb contained within.
I have been trying to source a ECU from a breakers, found one in your homeland, Ireland, funnily enough. However the part numbers are not an exact match.
My part number is 7M5T - 14A073 - CE, the one I have found is nearly the same expect the last digit is C i.e. 7M5T - 14A073 - CC.
The guy selling it says this can be re-programmed, is this the case?
