billybob66
Member Since 29 Dec 2012
Offline Last Active Yesterday, 09:07 PM
In Topic: Do You Like My Centre Console?
19 May 2013 - 08:50 PM
that looks great, might have to try that when the new headunit turns up this week.
are you going to change your heater dials??
In Topic: Steering Wheel Controls With Aftermarket Gps Help
08 May 2013 - 09:06 PM
hi aps67,
if you are fitting your new stereo in a mk 2 take out the stereo and check the wires on the bottom connector.
i too had this problem and it turned out to be that.
on your connector you have,
top block is power and so on
second block is for your speakers
and the bottom thin block is for your swc.
check these wires, on mine two of them where in the wrong place.
just remembered i bookmarked the page, :D
http://www.eonon.com...og/post/13.html
give this a read it tells you in better detail, hope it helps.
if not worth a try. ;)
billybob66
EDIT. just checked and the image has been removed but you will be able to follow the direction given.
In Topic: Loose Front Windscreen Trim On Y Reg Ford Focus Estate
11 April 2013 - 10:33 PM
hi rocymru,
any chance you could post a few pics to show your problem in better detail.
sorry to say i know nowt but some of the peeps here are gods, and could help with that little more info.
cheers, billybob66. ( learning loads from this forum from the gods. ) :D :D :D
In Topic: Car Self Diagnostics (Gauge Sweep Etc)
28 March 2013 - 10:43 PM
still getting same thing :(
please help a thicko. :D :D
billybob66, ;)
In Topic: New Dvd Satnav Unit Fitted (Pics)
16 March 2013 - 09:40 PM
Another quick question ...
I just picked up the reverse camera for the unit and on the video lead ( phono/rca - phono/rca) each end also has a thin red wire with bare end .
any thoughts or ideas what this red wire is ?
thanks in advance
is your camera one of the number plate ones?
if so could it not be the power supply to light up your number plate?
billybob66 :D
