Member Since 04 Jan 2013
Offline Last Active Dec 28 2014 03:48 PM
In Topic: Some Damage Advice
20 May 2013 - 07:25 PM
first things first you say you hit a bump in the road have you had a good look underneath the rest of the car because you could have damaged a lot more than you think ie brake pipes fuel lines best option take to a bodyshop that give a free estimate and then you can tell best option
In Topic: Ford Focus Rear Wiper
20 January 2013 - 02:37 PM
is worth checking the wiring between roof and tailgate because where you keep opening and shutting tailgate wiring in the rubber sleave gets crushed or broken which can cause a intermittent fault
20 January 2013 - 02:30 PM
Hi. I am asking for any advice or if anyone has had a similar problem. I have a 2005 ford focus zetec,recently my rear wiper has been playing up. When turned on it stops and starts in different places. The wiper does not do a fill rotation as it should. Could it be the motor? Any help would be much appreciated.
