shatherly
Member Since 05 Jan 2013
Offline Last Active Mar 07 2013 12:22 PM
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
01 March 2013 - 04:16 PM
Has anyone experienced the appearance of a dialogue box when starting up ELMConfig which starts/attempts to install Microsoft Project?
I have to cancel this attempted installation about four times before ELMConfig comes up. This applies to any version of ELMConfig and in both offline and connected modes.
12 January 2013 - 06:13 PM
I very much doubt if that would work. Anyway it is the PCM that needs to be changed, not the GEM. I think the reader needed is the Ford one.
11 January 2013 - 04:33 PM
Heya, got my cable working :)
Question: Anyone know if i can use this to enable the cruise controll ? Found 2 checkboxes (one from cluster, one from GEM) that you can tick to "enable" cruise controll. That made me wonder that if i go and buy the wheel whit the buttons, and enable it from ELM, it should work... right?
Second: Is there any way this could be used to recode injectors / do the reset to PCM and let the ecu re-learn the injector values?
I'm at the same position as you, except I have tried ticking the two CC boxes and I have fitted the wheel with the CC switches, but it doesn't work! I now need to get the PCM changed by someone with the appropriate kit (not the ELM 327).
