b19uks
Member Since 05 Jan 2013
Offline Last Active Jan 07 2013 01:12 PM
Ford Mondeo Tddi Strange Whooshing Noise When Clutch Depresed??
05 January 2013 - 10:14 PM
Hi Guys,
I get this weird whooshing noise coming up when i depress the clutch in to change gear in any rev or gears. The voice is like somebody is blowing air through a tube or pipe. I only get it when i depress the clutch.
I am stuck figuring out what can it be since i recently had the dreaded dmf failure and had all the associated parts changed
DUAL MASS FLYWHEEL
CLUTCH PRESSURE PLATE
CLUTCH DRIVEN PLATE
STARTER MOTOR
HYDRAULIC CONENTRIC CLUTCH SLAVE CYLINDER RELEASE BEARING
CSC RUBBER DUST COVER
All of the above was changed less then 3000 miles ago. Could it be that it could be one of the above that has failed?
Symptoms are different then the ones i had when dmf failed. Like the starter motor iron filings issue, Clutch getting stuck in etc.
What do you guys think it is?
Car spec: 51 reg mondeo tddi 98k miles.
