Carl0s
Member Since 08 Jan 2013
Offline Last Active Mar 08 2013 06:26 AM
In Topic: 1.6 Tdci Wount Go... Wait It Goes! Nope, It Wount...
07 March 2013 - 01:22 PM
How does the new engine differ from the old one - would the new engine have come with a VNT? is it the same CC etc
Im thinking the new engine is supplying more energy into the turbine?
is the electronic controller for the vaccum on the pumatic actuator connected/ working right
it may be possible to run the pnumatic actuator directly from the turbo (without the electronic part) the pnumatic actuator may be set to work at a set boost
Did you know with the fixed vane turbo you can fit a (seperate) adjustable electronic boost controller, so you could turn your boost up/ down as you drive?
Do you want more power or just want it running well/ reliable?
Its the same engine, 1.6 tdci 66kw version. Old one was -06 new one ~-09. All the numbers match... And ofc, the old one was 14 valve (valvetrain went haywire) ;) and the new engine is 290 000km less driven.
I could assume it works right. During engine braking boost drops to 0, during normal cruising its ~0,3 and when accelerating / driving up a hill its ~1.
Im not looking any extra power atm, just curious whats causing it, and how to possibly fix it. It doesent bother me that much, since you dont notice it on everyday driving. but it still bothers a bit :)
07 March 2013 - 11:13 AM
Does this happen in all or some gears? is it worse in some gears than others?
Even though the boost appears to be "steady" the boost control systems (actuator, MAF, VNTmech etc  ) goes up and down -
eg - you floor the throttle, more diesel gets sqirted into the engine, the turbine spins up, the compressor spins up, makes boost, higher boost pressure travels along the boost pipes, untill it reaches MAF sensor
Once the desired boost level is acheived (read by the MAF sensor) the ECU instructs the VNT to reduce boost -
This drops the boost pressure level coming out of the compressor, it then travels through the boost pipes/ intercooler untill it reaches the MAF sensor
Now, the MAF reads under the desired boost level, and the ECU instructs VNT mech to increase the boost,
The whole cycle goes round again, normally you are unaware of the (boost control) system doing its job, and it appears smooth
Sometimes, on a heavily modified car thats not set up right, you get this - its called "boost surge" "boost pumping" etc,  a lot of it is to do with the delay between the compressor and boost sensor (MAF) the "pumping" can be at a high or low frequency
is it an electronic actuator? is it off the old or new engine?
BOOST PUMPING!! Exacly the term i was looking before i tried to explaing the whole sin-wave thingy :)
The new engine was whitout any accessory, so only block, internals, head and intake. Everything else came from the old engine, and its the 66kw version, that has fixed vane turbo and a wastegate. The actuator for the wastegate is vacuum functioning, but the vacuum comes the vacuum pump via electronic controller. (what is hidden under the HP-pump on the back side of the engine)
I think its most notable when you are drivin whit ~2k rpm on 3rd or 4th, and nearly floor it (~80% of max).
The whoosing sound is similar what you hear, when you try to whistle whit dry lips, and you only hear the air movement :) (that was the closest thing that came to my mind)
I think i need to turn on the data-logging on my OBD adapter to get closer look of the boost preasure. Just incase the gauge it self has some lag and cant keep up whit the boost preasure change.
07 March 2013 - 09:27 AM
The engine was changed 2 weeks ago. Did the injectors too. Turbo had some radial play, but no axial.
EDIT: Hmm.. What kind of turbo noise? Since i can hear some "wshoooooooooooooooooh" sound during hard accelerations, that so far ive considered normal. (not much different what i heard on my mondeo, or what i can hear from my dads Kompressor MB...) :/
07 March 2013 - 09:04 AM
The power out put feels like SIN wave. You can feel it climbing up, then at the peak it starts to decline, and then climbing again. its pretty steady, takes like 1sec to do the "cycle" (from the power to the no power, and back to power). So its not like "snap" power off, "snap" power on, but smooth gaining power - loosing power - gaining power, and after 3k you get steady pull.
If feels bit like when you have cracked boost pipe, it holds untill some point, when it starts to leak (the gaining power, and loosing power cycle) after the preasure drops, it starts to hold again, and regaining preasure. But, this sould be visible on the boost gauge? I get steady boost of 1.0 - 1.1 (tho, somethimes it bounces back and forth between 1.0 & 1.3). And, when i changed the engine, i checked the boost pipes (tho, just spinned them around in my hands and gave em quick view).
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
24 February 2013 - 09:21 PM
Hey,
I have factory standard cruise, and the light does NOT light up on power up.
Ok, so it only lights up when the CC is active?
Hmm... I guess i need to wire up few pushbuttons, and test if the cc works by just enabling the Ticks on FF2, before buying the 4 spoke wheel...
