Support the club!
vince_13
Member Since 09 Jan 2013
Offline Last Active Yesterday, 10:22 PM
In Topic: Fitting Led's In The Footwell & Handbrake- Example On A Mk6.5
17 June 2013 - 08:07 PM
yh would still need to shave down the diameter of the plastic cowel to allow for the lights to shine through,
17 June 2013 - 06:08 PM
yh either way works, not particularly using sandpaper would work just as well
17 June 2013 - 05:53 PM
looking good m8
would finish it off with an ignition ring :)
http://www.fordowner...ition-led-ring/
In Topic: Mk3 Hcs Conversion
17 June 2013 - 07:16 AM
A new ecu would be needed, there are standalone management systems you can use which can be mapped, more useful on the 2.0 turbo
16 June 2013 - 07:16 PM
the engine will fit however the loom for the 1.3 would not be useable, you would need a 1.6 SI engine and car loom
with this replacement you can then run the SI 1.6 engine or fit the 1.8 engine or even make it run the 2.0 mondeo engine
