vince_13
Member Since 09 Jan 2013
Offline Last Active Today, 06:35 AM
#455630 1.6 Zetec Petrol - Just Me, Or Really Slow Off The Line?
Posted by vince_13 on 17 February 2015 - 05:19 PM
here is what worked for me
remove the air pipe that runs behind the front upper grille (black u shaped pipe) as this will massively improve your throttle response, add that to clutch control and you will see the difference,
few things to note:
takes a while for the car to adjust to the difference in air flow etc
your MPG will drop,
the air intake from the airbox will be exposed so watch those big puddles or invest in a slightly better air filter just incase
best thing about it is that your can simply attach the air pipe back on and its as original
#421525 Reverse Camera Trigger
Posted by vince_13 on 21 October 2014 - 07:55 PM
yeh 1.5mm is plenty, the camera wont be pulling that much current, (i presume there is a fuse protecting the radio anyway)
#421519 Reverse Camera Trigger
Posted by vince_13 on 21 October 2014 - 07:50 PM
thanks for your replys, I guessed it had to go to the reverse switch somehow , would it be possible to route the extended purple wire to the rear of the car to the live reverse light wire where I connected the camera and connect it there ?
thats where i picked up my feed from, (although im not using a sony headunit)
as said before get a really long wire and then tap into the loom under the car behind the bulb and test first, then you can lift the carpet in the boot and there is a rubber grommit on both sides just pick the grommit on the side your reverse bulb is and wire down to the bulb
#403088 Hassen's Ford Focus 1.6 Tdci Build Thread
Posted by vince_13 on 29 August 2014 - 04:16 PM
hi hassen great setup, how easy was the door speakers to swap?
as you have 2 amps 1 for your sub and the other is that to power the crossovers you have in the doors? is the second amp necessary?
#395637 Ac Recharge...
Posted by vince_13 on 08 August 2014 - 07:37 PM
the pop rivets down the left hand side (front facing) are prone to corrode and cause leaking, (on the mk2.5 anyway)
i had mine replaced with an aftermarket rad which had welded mounts on instead of the pop rivet mounts
#375287 Guide Fitting Second Reverse Light Ford Focus Mk2 & Mk2.5
Posted by vince_13 on 16 June 2014 - 05:16 PM
just to clear up and confusion, the plug on the right in the image below is what most people doing this mod will need, as the part on the left in the image already comes with a new LHD clear lens
with regards to polarity issues etc the pins are number 1 & 2 so a simple volt meter check will verify which pin is positive IIRC pin1 is positive
#374311 Guide Fitting Second Reverse Light Ford Focus Mk2 & Mk2.5
Posted by vince_13 on 13 June 2014 - 08:18 PM
ford wouldnt have it mate, they would supply the full loom only.
Sounds about right for ford
#374305 Guide Fitting Second Reverse Light Ford Focus Mk2 & Mk2.5
Posted by vince_13 on 13 June 2014 - 08:11 PM
Ive been searching for a while and my next step would of been to remove the connector from my car and go into ford but whether they would have them I doubt it
Sent from my C6903 using Ford OC mobile app
#374283 Guide Fitting Second Reverse Light Ford Focus Mk2 & Mk2.5
Posted by vince_13 on 13 June 2014 - 07:15 PM
Thanks lenny been searching for a holder for months
FYI theres still 1 left :)
#357437 Attempt To Fit Rear View Camera Went Up In Smoke
Posted by vince_13 on 27 April 2014 - 10:22 AM
me 2
i have the same rear view camera, connected between the reverse light and powered from the number plate light, the only difference being im viewing my image through my CD/Stereo so should be suited to the job in theory
great camera and nice image (if you keep the lens clean)
#349881 Vinnie's Project Log
Posted by vince_13 on 01 April 2014 - 09:21 PM
Good news I think I have found a reputable bodyshop finally, the ST spoiler and rear tow eye cover are currently being painted and will pick that up on Saturday
Just received my CMAX clear high level brake light with connector and wiring, which I hope will fit in place of the ST brake light in the spoiler
Small patch of rust on the drivers door will then be sorted finally
#335857 Vinnie's Project Log
Posted by vince_13 on 24 February 2014 - 08:21 PM
well not touched the car in a while, the task now is to get all the bodywork done (proving harder than i thought)
however im picking up a ST spoiler and once the front and rear bumpers are sorted and the rust on my door sill hopefully that will be all the bodywork sorted, ready for lowering
(thats the plan) :D
also working on some side projects being the interior light switches leds, the dual reverse mod and also the engine pipework
#329765 Interior Lights Stay On Following Windscreen Replacement
Posted by vince_13 on 06 February 2014 - 11:56 AM
Thry removed the light to acces the earth strip that is bolted near the aerial base, I presume this is for the heating elements,
They left the old earthing strip in my car and fitted a new 1 hence why removing the light
#329341 Interior Lights Stay On Following Windscreen Replacement
Posted by vince_13 on 04 February 2014 - 09:47 PM
i cant belive im reading this, i thought i was the only 1 and an isolated case
i was too a victim to there "workmanship" however in my case they had somehow blown the fuse when removing the light unit
in your case have you had a look at the black button slider on the reverse of the unit, it should pivot on 2 white pins, it may have come off center and not be moving correctly
#325735 Green Cotton Performance Induction Filter Fitting Guide
Posted by vince_13 on 25 January 2014 - 04:01 PM
recently installed this air filter and well impressed with the results, much smoother gong through the revs now not so much difference in noise (may have my music too loud haha)
well worth the buy
