- → Viewing Profile: Posts: tomsredfiesta
Support the club!
- Group Members
- Active Posts 4
- Profile Views 98
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
Mondeo Titanuim X 2.2tdci
Ford Year
2005
UK/Ireland Location
Lancashire
Annual Mileage
0 to 5000
Previous Fields
Location
Manchester
0
Neutral
User Tools
Friends
tomsredfiesta hasn't added any friends yet.
Latest Visitors
No latest visitors to show
In Topic: Howdy
17 January 2013 - 09:35 PM
Well I drove it to the Bodyshop a few weeks ago and was quite impressed with how nippy it was to be honest. I don't wanna do anything ridiculous, as I like to keep them in good original condition, but I was thinking of maybe a tuning box. Saying that, I've got no experience of them. I've got a mate at work who's got a 06 reg focus 1.8 tdci with a full ST replica conversion done (an excellent job - seats, dash, everything) and his has gone one on. I've driven it with and without and can definitely feel a diference.
In Topic: Ford Focus Tdci 1.6L Sluggish And Slow Acceleration - Possible Turbo Problem?
17 January 2013 - 09:01 PM
Can you hear any hissing from under the bonnet when you're trying to accellerate. It sounds like there's a intercooler pipe leeking somewhere. It could be a split (i.e. damaged pipe), or a loose jubilee clip or similar. If there are any leaks whatsoever in the circuit of pipes from the turbo down the the intercooler and through to the inlet manifold, it'll drastically effect the amount of boost the turbo can provide, as half of the air the turbo pressurises and blasts into the engine will escape.
It might be hard to find as it's a circuit that's got a lot of bends and joins in it, and it's in quite a confined space down the front of the engine, but as Silveredge says, a mate revving it gently while you look for a leak.
good luck!
TN
good luck!
TN
In Topic: Fiesta Mk6 Boot Light
17 January 2013 - 08:46 PM
The live wire to that bulb holder is a permanent live (obviously, because it needs to work even when the ignition isn't switched on) so you're right that the negative wire is the one that's switched.
The switch that controls it is inside the tailgate, attached to the inside of the latch. You'll need to open the boot and take the inner trim panel off. There's a couple of screws and a few pull clips. Get to the inside of the latch, and the switch looks like a little box about an inch long with a spring-loaded plunger in it.
I'd start there mate.
TN
TN
- Privacy Policy
Find content
