Sticky45
Member Since 11 Jan 2013
Offline Last Active Feb 23 2013 10:27 AM
In Topic: Interior Trim Removal.
23 February 2013 - 10:31 AM
Many thanks thats great. Like I said not afraid to strip bits of but words like airbag etc make checking a good idea. Right now all I need is a slightly warmer day.
In Topic: Zetec 100 6000Cd Bluetooth
10 February 2013 - 12:59 PM
In the glovebox there should be a grey circle top right. Connection is by 3.5mm jack same as most earphones. Its a good connection point but like I said you won't be able to skip via the controls. I'm just waiting for the ebay member to get back to me about their interfaces as they are ipod compatible. Although the ford music box is a good upgrade at thid moment I think 83 quid for a memory card reader is a lot of money.
09 February 2013 - 10:29 PM
I'll guesd like myself you do not have bluetooth, if like mine you have the silver curved corner unit you'll soon realise it is not mp3 disc compatible. Then you have four choices. 1) Replace unit for aftermarket stereo. 2) Replace stereo with a better spec ford unit. 3) Use the aux in in the glovebox but not be able to skip back or forward using your steering wheel controls or 4) Buy the music box available from ford that allows you to connect a memory stick and use your steering wheel controls (this however will not support an ipod etc and costs £83.
I have found a cheaper better version of the box on eBay but it appears these units wont support it as we don't appear to have a multi cd player output either.
Probably the most disappointing stereo I have seen in a car that should offer more.
In Topic: Guide To Installing The Ford Usb Music Box
07 February 2013 - 07:21 AM
Ok so after much searching for a picture of the back of my stereo with no success, could someone possibly confirm whether my style of the 6000cd has the cd multi changer output needed by one of the units posted previously.
06 February 2013 - 09:59 PM
Hmmmm. Found these on Ebay and has me wondering if this will fit my stereo pictured below. At almost half the price this could be a real find.
http://www.ebay.co.u...=item4ac120f88e
http://www.ebay.co.u...=item337faa2872
