Chris_B
Member Since 13 Jan 2013
Offline Last Active Apr 13 2013 07:18 PM
In Topic: 1998 Fiesta Mk4 Front Wishbone Replacement
03 April 2013 - 08:26 PM
Just an update for those of Interest,
Went back and undone all major bolts, re-fitted road wheels, lowered then tightened the bolts up to the required torque spec (80Nm), I also doused the Nyloc nuts in Loctite for added thread lock.
Took the car for a test drive and all is well. But I haven't dismissed the re-used bolts, I will go back and fit new ones. This stage is just to get the car through the MOT.
Update: Car passed MOT with success, I will go back and replace the bolts on the front pivot pushes
Chris
In Topic: Fiesta Mk4 1.25L Zetec Timing Belt Renewal
03 April 2013 - 08:17 PM
Is the crankshaft pulley bolt a left handed thread on the Zetec engine?
Many thanks, Chris
01 April 2013 - 08:52 PM
Chris
31 March 2013 - 09:42 PM
Thank you DieselPig, I will go back and re-do my work, best to be safe.
17 January 2013 - 09:41 PM
Hi, think I'm going to buy a flywheel ring gear locking tool from Laser and remove the starter motor to fit this, just received the timing tools and Haynes manual for a bit of guidance.
I don't think i will try putting the car in gear and locking the brakes, i think that would damage the clutch and drive train to be honest.
All i need now is the camshaft pulley counter torque brace and a crankshaft pulley.
Once i get the TDC lined up with the locating pin then i can lock the flywheel and apply torque when i refit the belt, and as for the top end, i think i will fabricate a 'Y' joint flat bar with M10 or M12 bolts and hold the camshaft pulleys in place against the engine bay top support with a piece of wood underneath the holding bar.
Will post once i complete the work with pictures.
Thanks for reading.
