Dixie diesel
Member Since 13 Jan 2013
Offline Last Active Jan 31 2013 09:44 PM
In Topic: Focus 1.8Tdci Low Mpg And White Smoke On Start Up
30 January 2013 - 08:30 PM
Hi many thanks for remembering me.........had my car in for diagnostics,....no faults showed so they put some injectors off of another focus to see if there was a difference,, unfortunately no change there!!! Still misfires terribly on first start up..so yesterday had my original injectors put back and seals redone...a wire was almost through on one of the injectors so that's been repaired but not the problem either.... Have bought some forte injector cleaner to put through but next step is to replace either the fuel filter or the car!!!!!ford garage have absolutely no idea what's causing the misfire so anythings worth a try at mo....such a shame asthe car is fantastic once it's warm...runs a dream and so responsive....takes on any boy racer!!!LOL...
16 January 2013 - 09:16 PM
Many thanks for your replies..unfortunately mine is now down to 30mpg and misfiring even more than ever!!!also now stops on me too........still misfires when warm too!.....normally I run esso fuel as no local shell garage.makes me wish I had kept my little Clio diesel...only had this car 3months and really starting to regret it........thanks again for the replies x x
16 January 2013 - 07:46 PM
Thanks for asking about my car..I had the turbo pipe checked as apparently that can cause these problems and that's ok so ford are doing diagnostic on it on the 25th...now it's just a case of wait and see....fingers crossed its not the injectors as I've been told cost is around 1000......when I get more info I'll post it for others to see...
13 January 2013 - 10:04 PM
Ok will do.luckily my garage is very good and doesn't rip u off so will keep u up to date...many thanks again.have a good evening.
13 January 2013 - 09:58 PM
Service book was stamped..would egr valveshowup on diagnostic as booking in for this 2moro?think I'd best get fuel filter done at same time.new to these forums so a bit slow... Up at 5 so off to bed now many thanks for your replies will check forum 2moro..nite for now and thank you again
