charikaar
Member Since 15 Jan 2013
Offline Last Active Mar 17 2013 12:27 PM
In Topic: Ford S Max Full Computer Diagnosis
10 February 2013 - 12:42 PM
I found the following fault codes on this car
DTC 01 F00616
DTC 02 C41668
DTC 03 C18400
Do these suggent major issues with the car?
In Topic: Anyone Know What This Part Is Called.
25 January 2013 - 06:31 PM
Just got some more photos off ebay for the similiar engine. CAn you see in pic 2 the hose coming from back to front. Don't know where it connects at front.
All sorted. I have connected the hose as shown in this engine. thanks everyone.
25 January 2013 - 06:10 PM
PA6-GF35 (matches with other part above)
AV61-9C623-B
N07011C160
N07011C170
25 January 2013 - 06:08 PM
showed it to a mechanic who charged me £40 and said this connects to the air filter box but we have just installed the air filter box and there is no such places where this part will connect.
we have one spare hole as pictured. Do these two bits connect together.
this part is connected behind the engine and numbers on it are
AV61-9C623-B
N07011C160
N07011C170
25 January 2013 - 02:28 PM
1/
The electric pre-heater (on a mk3 Mondeo ) is alloy, it is a straght "torpedo"-like tube with 3 electrical connectors (for the 3 heaters) it connects between the thermostat 19mm "heater" outlet and the cabin heater, it is located at the front of the floorpan/ scuttle (just about where the drivers' feet are but on the other side of the bulkhead) it is visible with the engine undertray fitted, from under the car.
it helps to warm the water/ coolant before it goes to the cabin heater
Some Mk3s had deisel- burning heaters instead (for cold climates - eg for Scandanavian countries etc) the mk3s always had a over- cooling/ not producing enough heat problem - thats why iv'e fitted an (electronically controlled) electric waterpump to mine (and for other reasons) - ive removed my heater and some of the pipes as part of the conversion (don't need it because the electric waterpump only comes on when the engine is warmed up, and it warms up much quicker )
2/
The charcoal (carbon) evaporation canisters are fitted to petrol cars to prevent (or safely filter) petol/ fumes/ gasses escaping into the atmosphere from petol tanks on petrol cars and still allow the tanks to be vented (its another "emmisions" thing)
Its not really nessesary on a diesel (i think mine has a sealed tank with an "expansion chamber" built in to the top of the tank) but thats never stopped them fitting parts designed for petrol- engined cars onto deisels, that should'nt really be there (eg - EGR valves/ systems)
3/
I think it is the oil cooler/ seperator or an associated component
On the mk3 Mondeo diesel engine, there is a watercooled oil cooler on the bottom/ front of the engine, a small thermostat comes out of the side of the waterpump where it feeds a coolant hose then goes to the cooler/ seperator, there is another coolant hose that returns to the radiator
it is (part of) an oll cooler that uses the engines main coolant/ radiator, controlled by its own thermostat (not like a seperate oil cooler radiator like the ones on a race/ performance car )
so water (coolant) and oil runs through it - there should be a water coolant/ in/out and an oil in/out
Do i get a prize if im right? :)
option 3 looks good to me. I went to ford this morning and they showed me this part on their system but couldn't find me hose coming out of this bit.
