sjs
Member Since 07 Feb 2009
Offline Last Active Jan 19 2010 08:50 PM
In Topic: Steering wheel question.
18 March 2009 - 07:18 PM
Thanks, we are having trouble finding a good 2nd hand fester wheel and thought if the focus was similar it might be worth a try, but we'll just have to keep looking for the right fester wheel, are the mk6 and mk7 the same fitment?, thanku
17 March 2009 - 09:17 PM
Hi, will a focus wheel fit the mk6 fester?, cheers
p.s. speedo problem was caused by dash needing calibrated.
In Topic: Mk6 Problems
03 March 2009 - 08:31 PM
Hi, can it be made into a decat pipe?, and then pass MOT?.
03 March 2009 - 07:55 PM
Hi, thanks for the replys, a few more issues, cracking window turned out to be regulator fault, new washer jets ordered to stop water leaks which could have caused a major problem!, engine light came on the other day and ford think the cat is blocked, when driving the car home after ford looked at it but hadn't worked on it, i noticed the speedo wasn't working and the mileage wasn't showing, is this part of having the engine light on or is this another problem?, is there a way of fixing the cat without replacing it?, or is it a straight replacement?, thanks
08 February 2009 - 11:34 AM
Thanks, the washer pipe isn't actually burst it's letting rain water in between the jet and the bonnet, is there an upgraded jet with a better bonnet seal?, cheers.
