Support the club!
kevctr
Member Since 20 Jan 2013
Offline Last Active Jan 23 2013 08:38 AM
Mondeo Fault Code Help
20 January 2013 - 11:11 AM
hi all im new to the forum and in need off some help iv searched the net and im getting confused with all the answers as they seem to say opasit things
i have just brought a 03 mondeo 2.0 130
when u drive the car u get the glow light flashing then car cuts out totaly if u turn it off and on again it will restart and keep going till the next time and so on iv had it checked and results were
fault codes are
p0251 injector pump meter control ?
p1000 test incomplete ?
u1039 vehicle speed signal missing or incomplete ?
p1211 injector control pressure sensor above/below desired ?
i had a diesel leak from the piep that goes up the back off the manifold from injector pump up to the injector rail so iv orderd a new pipe and will be fitting tomorow
im in need off some help trying to understand the cause or understanding the fault codes
i know these cars have a problem with injectors and in an ideal world i would say just replace everything but i cant afford to do this
so im trying to understand the codes so i can try and narrow down the problem
any help would be great many thanks kev
