Member Since 20 Jan 2013
Offline Last Active Jan 26 2013 06:38 PM
In Topic: Front Wheel Hub Nut Loose
25 January 2013 - 10:20 AM
It seems after the work had been done on it, it was tightend to a strong enough defect. Check it weekly once re-tightend and ensure of no looseness again. If there is, due to lack or non locking at all, it might be that the treads have worn so therefore need replacing. Not to costy at all, however could be if not put right, as with any moving part! Hope it's all sorted soon for you!
In Topic: [Help]2001 Ford Mondeo - How To Move Mirrors
25 January 2013 - 09:59 AM
So where's this picture! Glad you sorted windows out, always a nightmare not being able to exactly what you require! Was there no log book with the car?!
In Topic: Battery Being Drained Flat On 59 Plate Mondeo Edge Estate.
24 January 2013 - 03:27 PM
It sounds very much like a loose earth, had the same issue on a Fiesta! However like with anything these days something so small as an interior light can drain the whole battery in hours! Be sure that all is switched off, I know on the fiesta that even if I did not manually and physically turn the radio off via the on/off button, then it would hibernate but drain throughout its off time.
In Topic: Help! Looking For A Few Parts!
24 January 2013 - 02:17 PM
This is just it, I'd rather pay Vospers or another manufacturing company. With the engine cover, the foam underneath is worn away, is this ok to fit without it?
21 January 2013 - 05:44 PM
I would prefer OEM, however mudflaps to fit a Ghia are proving to difficult for me.
