Support the club!
Chris R
Member Since 21 Jan 2013
Offline Last Active Jan 27 2013 08:20 PM
In Topic: Ford Focus 1.8I Ecu
27 January 2013 - 12:03 PM
hmmm, ok. I will check the ECU from my other car as It did start up with it and the chip of course, the only thing i remember is it said OPEN instead of TEAR. do you know if Ford would be able to program keys (including the master blue chip key) into another ECU?
Thanks again
27 January 2013 - 10:48 AM
Hi, you were right about the marking, this ECU pictured is the one that was loose in the car and is hopefully the original one!
can you tell me which numbers I need to match up if i get an ECU kit, or does it not matter if I get a full kit, ecu keys locks etc.
Many thanks
Attached File  ecu.JPG   124.31K   9 downloads
26 January 2013 - 06:10 PM
Hi, thanks for your answer, I forgot to put that sombody already put a 2nd hand ECU in and that was either dead or not programmed to the key!
So I'm not even sure which is the original ECU as neither will run the car. (there was a 2nd ECU loose in the car)
Regards
