duluxdoggy
Member Since 21 Jan 2013
Offline Last Active May 12 2013 05:47 PM
In Topic: Sony 6Cd Head Unit
16 March 2013 - 08:04 AM
hi. sorry foe delayed reply, i have been in work, i have removed the unit again and taken a side by side photo,
as you can see there is a massive difference in the two units, is it even possible to use a normal unit in the ghia car??? i very much doubt that ford would use a completely different dash layout,
im getting fed up with this issue, may just get a cheap adapter kit and fit me trusty kenwood single din cd player. i have been avoiding this as i wanted to keep the remote on steering column
15 March 2013 - 06:02 PM
this is the ebay listing i bought it from, as you can see it is wider at the top, but the angle is different
i thought i was buying a mondeo unit
15 March 2013 - 05:48 PM
ok, so i remove the head unit, and it has already had an attempted repair job. but either way, its goosed. so i go on ebay and buy a ford 6000cd head unit, but, i just ent to install it and it doesnt fit... see photo. any idea what ford stereo will work??
01 March 2013 - 11:22 PM
It sounds like you have a tray error or the laser head has jammed.
Try disconnecting the power to the radio by yanking the fuse to cause a radio reset.
Make sure not have your radio code first though!!!!!
Worst case scenario is you'll need a replacement radio.
Don't go to Ford as they'll charge you about £500.
Also be very sure it's a mondeo radio you get as they are a different fascia shape to the ones in a focus/fiesta and are also deeper in the casing.
i will look into this later, i need to get some keys to be able to remove the unit. and if i need to replace the unit, im not going to, i dont have any music on cd anyways. i just use spotify. only bouhg a cheap cd to test it! kinda wish i didnt now
01 March 2013 - 10:31 PM
no, the eject and load buttons dont do anything, it wont go on cd mode, i am assuming that is why they dont do anything, i have no way of knowing if ther is a disc inside already or not.
