Update - the clutch now works. Turns out it was a sticky clutch plate. One thing to woo hoo about because the car now moves.
However, I have the wonderful engine light on. The car doesn't have any oomph behind it and mpg is pretty poor. No idea yet what it is, so I've ordered a code reader to reset the ECU, drive it, wait for the errors to pop up and then run a diagnostics on it again so hopefully that will shed light on the mattter.
- → Viewing Profile: Posts: KBatt72
Support the club!
- Group Members
- Active Posts 7
- Profile Views 100
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Female
Ford Model
Focus 2.0TDCi
Ford Year
2005
UK/Ireland Location
Sussex
Annual Mileage
0 to 5000
Contact Information
- First Name Kelly
0
Neutral
User Tools
Friends
KBatt72 hasn't added any friends yet.
Latest Visitors
No latest visitors to show
In Topic: 2.0Tdci Clutch Issue
02 February 2013 - 02:24 AM
23 January 2013 - 06:07 AM
Got rid of the old thread
Thank you very much!
I am hoping it is not the crankshaft. Trading Standards are aware of the problems, the ball is rolling on it but that alone is a long winded thing with no gurantee of a result going my way. Needless to say I am glad I have Ford diagnostics papers.
The gearbox doesn't grind no, clutch feels as normal, you can't select gear when the ignition is on, but you can when it is off. If you start the car in gear the car jumps.
I believe dad has begun to dismantle everything again to remove the gearbox.
In Topic: I Asked Car Dealer They Said We Don't Have In Records For Key Code
22 January 2013 - 09:55 AM
I did contact. They said they don't store those codes. Fortunately I found my code, but I thought it was rather strange. £30 for a nut key. I never thought Ford would be more expensive than BMW
22 January 2013 - 08:57 AM
Thank you FOCA for your prompt reply. I can't answer that quite yet but I have printed off your message to give to my dad to read shortly when he is home.
Andy Dibley - If you start the car in gear even with your foot on the clutch it jumps. (This was after the nipple bleed but before the pressure bleed) When the engine is not running you can select gear, but when the engine is running you cant. You can hear the revs change very slightly as you try to push it into gear. The clutch peddle feels as it should.
I know when we have had the car out of gear and ignition off, the gears can be selected from the engine bay as well.
UPDATE: I showed dad the message and he informed me he has tried. The flywheel kit was produced by SACHS. Dad contacted them to confirm the part numbers.
He is hoping it is the pressure plate binding on the input shaft but said that worst case it could be that the crankshaft is bent which is prone to happening driving with a damaged flywheel.
22 January 2013 - 02:03 AM
I have learnt that Ford are not particularly useful. Just make sure you do not lose the key code for your locking nuts otherwise you will be drilling them out!
- Privacy Policy
Find content
