can anyone help me i,ve got a fiesta 52 plate duratec engine that starts and runs fine but as it gets up to temp water starts to come out of the water tank faster than it went in so my first thought was water pump or thermostat so changed the pump and took the stat out still the same flushed heater through and other pipes still no change engine dont over heat atall and dont seem to be mixing with oil thanks for taking the time to read my drama any help please
Hi there all, I have a ford fiesta Finesse 2002. 1.2 engine.. now im having a bit of a problemm. the water doesn't seem to be pumping around the system, pipes around the thermostat are getting hot but nowhere else is, water in radiator is stone cold.and the heaters only blow cold air.. and it is now leaking oil.. any suggestions appreciated.
Hi there all, unsure on if this is what im supposed to do..
Latest Comments
More
