You will need to feed your "live" wire (red one) either through the bulkhead (should be a plastic cap over a small hole on the passenger side footwell of the car) or feed it under the wing and into the car.
You will have to take the door sill off and feed the wires under the carpet.
Make sure your phono cables are ran along the opposite side of the car away from the Live cable to save on interference.
Best place for the "Earth" cable would be the bolts on the lower boot latch.
IMO I would mount the amp and sub on a piece of fitted wood and drill in place to save it knocking around.
Welcome along Gary, hopefully you wont find your separation from the french (and the Japanese bit on the side) too uncomfortable!
what brought you to the blue oval then?
well it was a good choice of car for the price to be honest, picked it up for £2600 with 65k on the clock, 2 owners, can belt and air con/steering pump (cant remember) change at 61k with full service history. The chap before has put some 16" graphite alloys on it, lowered, smoked the rear windows and fitted a cat back so I couldn't argue
Latest Comments
More
