Member Since 22 Jan 2013
Offline Last Active Yesterday, 05:02 PM
#542929 1.8 Tdci Ticking Noise?
Posted by dogdays1 on 23 November 2015 - 01:58 PM
As you have  mentioned rocker arms in you post I wonder if we are all talking about the same engine, as my 1.8 TDCI 4 cylinder 8 valve Endura Diesel did not have rocker arms, as the cams worked directly onto the valve buckets.
#299668 Ford Focus Or C-Max 1.8 Tdci Engine Wiring Loom
Posted by dogdays1 on 25 October 2013 - 10:21 PM
It seems rather dramatic to seek a new loom when all you say you have damaged is the plug.
Surely its possible to find a breakers with a smashed car, cut the section of loom that goes to the ecu, then splice the new plug and cable onto your old loom with connectors.Its not as if this is a new car.
I will go look at my 1.8tdci Focus in the morning.
Incidentally, do you find your EGR  gives a shushing noise at certain throttle openings? Mine always has.
