Member Since 22 Jan 2013
Offline Last Active Feb 03 2013 06:41 PM
2005 Mondeo Tdci Cuts Out On Return To Idle, Help Please! :(
22 January 2013 - 06:48 PM
Hi all, new here, just entered ford ownership and having trouble..........
Full story :
2005 mondeo tdci 130
Bought with a noisy dual mass flywheel, I used the car for 3-4 days and it was fine, dual mass rattled and starter was goosed, so parked it up until I could do it.
So on Friday, I fitted a dual mass delete, so solid flywheel, clutch and slave cylinder, new starter motor. No problem.
During fitting we noticed the crank sensor had been rubbed, but I felt it was ok before so should be ok now. Wrong....
I serviced the car, fram filters, oil, air, pollen, fuel etc.
On the drive home I came to a junction and it just cut dead, started up instantly again.
Did it 4 or 5 times, I just presumed the sensor was knackered, so replaced it. No different at all.
So if you sit and rev the car to 3-3.5000rpm and let off it stops, or if you drive and come to a junction etc it will do the same.
No lights on etc, anyone got any ideas?? Fed up with it already! :(
Serviced, oil, filter, air filter, fuel filter (fram parts) used.
On the d
