Just bought myself a 52 plate ghia estate. The running of the cars seems fine, but its the little things you don't notice on a test drive. It's got a couple of leaks with the washer system. The first is - I think the washer fluid bottle has got a leak, it needs refilling every couple of days. I've had a look on the forum and it seems as though this has happened to a few others and it's hopefully any easy fix with some silicone gel, but any further comments would be appreciated.
The big problem is the rear washer. When I go to wash the rear window after a few seconds water appears to pour through the roof lining and down the grill on the inside passenger side. I had a quick look under torch light tonight and saw that the lining is damp on the underside. I'm not sure where the leak is coming from although I can see that there are a couple of pipes connected and this connection could be the culprit. Does anyone have any thoughts on this, I can't find anything on the forum, or other forums for that matter, with similar problems. Do the pipes perish easily and if so are they an easy fix? Like I say it's localised to the rear of the car only.
Of course I could not bother with cleaning my back window, but this weather and long journeys means visibility reduces fairly quickly, so i'd like to wash it every now and then.
meesterbriggs
Member Since 22 Jan 2013Offline Last Active Jan 22 2013 07:58 PM
Find content
Not Telling
