Hi All
Focus virgin coming across from a Rover 45
Just purchased a MK1.5 2003 Zetec which has a minor issue which the previous owner had his garage attempt cure but apparently no luck .
The rear wiper stops working on occasion and the roof lining is currently not correctly seated by the the tail gate rubber seal.
I was looking in the dark when i got it home from picking it so not the best conditions but how does the roof lining attach are they normally glued ?
The foam and the fabric have separated so i do i need to glue that back together and whats the best adhesive to use if needed?
i've done some research on both the roof lining and this intermittent wiper issue but not really much joy apart from the wires can break from rubbing against the roof.
Thanks in advance.
verved
Member Since 23 Jan 2013Offline Last Active Jan 27 2013 06:40 PM
Find content
Not Telling
