Member Since 29 Jan 2013
Offline Last Active Feb 07 2013 06:31 PM
Mk3 Mondeo Abs Problem
02 February 2013 - 07:13 PM
ive been very busy today ..
changed my rear speed sensor and hub . to find out . that . its not the sensor ... its the wiring .... there no power at all going into the driver side ABS Loom . but 11v going into the passenger side .... ???? any ideas ????? the only bit of power its getting is 0.05v ???
Mk3 Mondeo Tdci Problem
29 January 2013 - 10:12 PM
just brought a mk3 tdci euro 4 engine 55 plate mondeo
the problem is really wierd
if u drive it hard after 3000rpm it will go into limp mode ... but if driven sensibly it will go all the way round the rev range ????
when i brought it the guy said it has had a second hand turbo actuator on it . as the old 1 failed .. . and he was told sometimes they need recoding ??? is this true ?? or not ???
also today i unplugged the MAF Sensor ( airflow meter ) and the car didnt run no different ..... but im sure it should of ran lumpy and smokey with out that connected ?????but the engine management light did come on ??? but went off when reconnected MAF Sensor .
it starts first time in a morning . no smoke from cold when started . and no smoke when driving .... engine is a little knocky but put that down to a diesel knock
the things i have tried is
Clean EGR Valve
Unplug MAF Sensor ( Changed MAF Sensor as it brought code p0100 up )
Changed Boost Pipe As it was split
Changed Airfilter As it was black ....
checked for a power feed to MAF - All Workin Fine
What else could it be ????
its got 148k on clock ....
Im still getting 40mpg combined ....which i think is good ???? and around 35mpg round town .....
29 January 2013 - 10:10 PM
hi my names john im 23
and drive a mk3 tdci 130bhp mondeo ..
from nottingham
