Member Since 31 Jan 2013
Offline Last Active Aug 05 2013 10:52 AM
Fix Egr Or Place A Blocking Plate?
01 February 2013 - 07:57 AM
My first post here. So hello to all!
I have a 2008 Focus 1.8 TDCi (face lift model) having read allot on this forum it appears that the TDCi engines have a common issue with the EGR. I have the same problem with my car, when under high revs (above 2.5) mainly on 1st and 2nd gear after pulling off from a stop it stutters and sometimes gives an engine warning on the dash which will put the car on limp mode. I spoke to my mechanic and he pointed to the EGR which I also suspect is the cause of all this.
My question from an newbie to you experts :) is;
Shall I clean the EGR or block it with a plate? If I block it, would there be any performance issues ? Your thoughts / experiences would highly be appreciated.
