Frosted666
Member Since 31 Jan 2013
Offline Last Active Mar 27 2013 09:21 PM
In Topic: Fiesta Mk7 Zetec S Mountune Performance (Ps155)
18 March 2013 - 04:20 PM
You could bolt on the parts, drive to your mapping session and they should be able to adjust the boost via the ecu and map the car. Only a guess as im unsure about the ecu on your car.
18 March 2013 - 04:17 PM
Yeh most people wont have one to hand but there are apps for phones and i know that the ones on the iphone are rather close, only a couple or db's out either way when tested against a proper db meter.
I use an app called Decibell ultra on my iphone. Its free  :)
18 March 2013 - 04:00 PM
OMG, the headlights are and pain on the mk7 but not sure about mk7.5 but knowing Ford they are nightmare. There is guide to changing them.
I dont think think Mountune 155 or 140 will be suitable as the ecoboost is a different engine.
Its a turbo one so you can up the boost, intercooler and better exhaust and intake and see some power.
In Topic: Bluefin Now Available For Mk7 Fiesta 1.6Ti-Vct
18 March 2013 - 03:56 PM
Sorry to revive this old topic but I'm thinking of doing the 140 or 155 Mountune or a similar upgrade but as this will be done to my daily car I don't want to have it to loud.
Any idea's on the db reading inside the car on the motorway at about 80mph?
And what's the mpg impact? Increase or decrease and if so roughly how much?
I have watched loads of videos and they all vary on their volume and there are just to many variables and trolled through the forums, youtube and even called Pumaspeed, Mountune and Miltek and they don't have a db reading.
In regards to the superchips bluefin and j1 kit it should make a slightly bigger increase as your only increasing the amount of air being taken in and the air sensor will detect that and the ecu will adjust accordingly but with the exhaust you will gain very little, the gain will be only what you gain over the standard without the superchip bluefin. I would not expect to make a bigger increase with the bluefin with a full Miltek exhaust and j1 only the few extra ponies it gives you over the standard map and parts.
A mapping session would be advised and the upgrades will be fully utilised and whilst your doing that you might aswell put some Pipercams in too and then you shall see some power, but the bluefin would still give you some extra ponies but doubt it that it will work with the cams.
Pipercams do two versions, sport and ultimate sport.
18 March 2013 - 03:39 PM
:rolleyes:
