Thanks for all the advice - I have driven the car 500 miles since renewing the calipers again and all is well - no sticking of calipers or overheating. The handbrake adjusters seem to have settled in and the handbrake levers are more even and almost back to the stops once the handbrake is released.
I checked out the caliper sliders and pins and they were all perfectly straight and free. Renewing the handbrake cable clips which fit to the lower suspension arms helped by routing the cables better.
I think the main issues on my car were sticky handbrake cables, and partially seized handbrake mechanisms in the calipers. The problem was not helped by the first pair of calipers being defective and having the incorrect fitting procedure. I am convinced that the guide pins/sliders will only become bent due to the pins on the pad backplates being misaligned with the cut outs in the caliper pistons, or possibly seized pads in the calipers, which results in the pistons applying unequal pressure to the pads/pins/guides, causing the pads to wear wedge shaped and the slider guides/pins to become bent.
It just goes to show that the symptons can sometimes be similar but the causes of problems can be different!
Thanks again to everyone who contributed.
- → Viewing Profile: Posts: Steve TDI
Support the club!
- Group Members
- Active Posts 4
- Profile Views 110
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
Mondeo TDI MK3
UK/Ireland Location
Buckinghamshire
0
Neutral
User Tools
Friends
Steve TDI hasn't added any friends yet.
Latest Visitors
No latest visitors to show
In Topic: Ford Mondeo Mk3 Tdi Rear Brake Sticking On. Help!
11 February 2013 - 11:57 AM
08 February 2013 - 10:14 AM
I fitted the new calipers (second set) using the revised installation instructions from the suppliers (first set had wrong instructions) which were as per manual except the new calipers were modified type with two identical "cut outs" in the piston face, rather than the originals which are different, which means you can fit them lining up either of the cut outs with the mark on the caliper body, making sure the peg on the pad backplate also lines up. Wound back the pistons/handbrake mech, bled brakes, operated footbrake, made sure peg on pads lined up, only connected up handbrake after pads bedded in. Following this operation of handbrake seemed to be better although there was more actuation on the RH handbrake lever, and this one was well off the stop when handbrake is off. LH one almost goes back to the stop. I think difference is down to the handbrake self adjuster not fully settled in - hopefully it will in time. I noticed that lever return springs on the new calipers were not as strong as the originals, so I fitted the originals and levers seemed to return towards the stops better.
I have driven the car 3 or 4 times since doing the above and so far all seems well, no brake binding or overheating, but I have ordered the proper Ford handbrake cable guides which fit on the suspension arms as I think the cable will sit in a better position rather than at present with the cable ties which are in place. Fingers crossed this will be the end of the problem!
02 February 2013 - 05:05 PM
Hi - thanks very much for your post.
I will check out the guide pins as suggested. I am not sure though that this will be the answer for my car, as the pads are not wearing unevenly as far as I could see and I have had no problems with the brakes sticking on once I pull back the handbrake levers to their stops. Its as though there is a hydraulic action within the caliper which stops the handbrake from de-activating fully.
Thinking about your problem, I have always been careful to make sure the peg on the pad backplate lines up with the correct recess in the caliper piston (lining up the piston recess with the mark on the caliper housing) as if it isn't the piston will not be square to the pad, the pad will wear to a wedge shape and I would think with everything being out of line this could well bend the guide pins - just a thought that this could have happened in the past before you had the car??
Thanks again, and any further suggestions from anyone who has experienced similar problems will be gratefully received
- Privacy Policy
Find content
