Hi im new to this hopefully someone can help me out
i have 2001 2.0tddi mondeo i start the car up from cold with in 20sec the twin rad fans are running, they run for a bit then stop then start up again.
ive checked all the fuses and relays i also fitted a temp sender in the head thinking i was sending the wrong info the the ecu,
ive turned the heater control off the screen and and turned the blowers off
i have got hot air coming from the heater and there is water on the max line of the coolant system
has anyone else had this problem and know how to fix it
thanks mike
deadmantalking
Member Since 03 Feb 2013Offline Last Active Feb 09 2013 11:03 PM
Find content
Not Telling
