Hi, I'm reluctant to go to ford with this as it's already cost enough!
I have a 2005 mk2 2.0tdci 136 focus. For the last couple of months i've been having problems getting it started from cold. It's had new glow plugs, new EGR valve, new battery, but not fixed.
From cold, it may or may not fire up first time but then after running for a few seconds at idle it dies. I can get around this by reving the engine for a few minutes (not ideal when it's cold!). Sometimes though the revs will drop whilst I still have my foot on the pedal, then pick up again. After revving for a little while it's usually ok and I can set off (once it did die again when i dipped the clutch to change gear just aftyer i'd set off-not ideal in the mioddle of an industrial estate!). After a few minutes it works fine and there is nothing wrong with the performance. The problem doesn't really happen when the engine is warm either. It's been to my local garage (v good, but not diesel specialists), as well as a diesel specialist place-neither can identify the problem, which makes me thionk it's electrical.
I have had a dig around on the forums and it seems like there are loads of potential reasons e.g. cam sensor etc...I don't really want to pay ford to look at it all day then say its a £25 sensor!
Anyone had the same syptoms??
AL85
Member Since 05 Feb 2013Offline Last Active Feb 13 2013 10:23 AM
Find content
Not Telling
