Support the club!
Gavin Montana
Member Since 05 Feb 2013
Offline Last Active Feb 24 2013 10:17 AM
Central Locking
24 February 2013 - 10:16 AM
Hi been having trouble with the centrall locking on my 1999 ford focus 1st after i put new batteries in the remote ey fob and reprogrammed everything worked then the drivers door started not locking, then the drivers door wouldn't lock or unlock, now using the key the rear drivers passenger door doesn't responed to the key only way is to lock the door with the deadlock before turning the key, and reverse the process to unlock the door any hel please i'm not sure if the key is programmed coorect do i follow the handbook and clear the imboliser first
Rear Door Handle
10 February 2013 - 10:10 PM
Hi after opening the rear passenger door today the handle didn't fully return to its correct ostiotion anyone now the cause and remedy for the problem
Romote Control Key Fob
05 February 2013 - 11:29 PM
I bought my t-reg focus 1.6 zetec a couple of weeks ago and both key fobs had no batteries put new one in and nothing happened found a programming guide on the net, fob worked fine for a couple of days then fob wouldn't unlock or lock drivers door, reprogramed fob again didn't cure problem and sometimes with the other doors(mines a 5 door) you press the lock button and they lock and unlock, anyone has any ideas, all doors lock/unlock with the key
