Member Since 06 Feb 2013
Offline Last Active Apr 15 2014 03:31 PM
In Topic: Omex Install & Speedo / Fuel / Rev Gauge Not Moving
15 April 2014 - 01:38 PM
In Topic: Short Lived Drive Home!
15 April 2014 - 12:12 PM
Lucky you!
I'd still report the pot hole to the council then wait 24 hours and if it's not fixed, you can then claim.
Over-exaggerate the problem get a few $ outta them
Burst tyre, buckled alloy, Alignment out of track
atleast £2-400
In Topic: Plasti Dip
02 August 2013 - 11:52 AM
I got my roof done with plasti dip.
The only downsides are;
In heat it feels rubbery
Bugs stick to it!
it scratches easily (but not your paint work, just the dip!)
A bird pooped on my roof, and I tried to remove it using water and a cloth... that's how I got the scratches.
You're not supposed to use power washers - but I found that's the best way to clean them.
It's the cheapest option, a full car costing from £250 - 500 whereas vinyl can be 700 - 1.5k and paint can be upwards of 1.5k
a real good paint job is obviously the BEST option but expensive.
the plastidip - apparently is easier and leaves less residue than vinyl - which can tear off the paint too.
In Topic: Iphone Jack / Usb
02 August 2013 - 11:25 AM
http://www.amazon.co...tte lighter usb
that might work?
In Topic: Alloy Wheel Colour Change?
02 August 2013 - 10:50 AM
If you plan on handing it back... I'd probably stay away - or just get them plasti dipped that way you can peel it off (like vinyl wrapping) after you're done and handing it back.
