I have got a new rear hub and wheel bearing assembly that I need to fit to my Mk2 2.0 Focus. The Haynes manual says it is bolted on with torx bolts. I do not have any torx sockets, and money being tight, I don't want to buy a compete set of sockets, I will just buy the one I need, so can anyone tell me what size torx socket I will need.
Also, is it possible to unbolt the rear caliper without disconnecting the hand brake cable, and just tie it up whilst removing the disk and hub? The new hub did not come with new bolts, and the Haynes manual does not say to replace them, so I assume it will be ok to re use the old ones with some fresh tread lock.
Cheers.
Phil.
Find content
Male
