- → Viewing Profile: Posts: paulinsuffolk
Support the club!
- Group Members
- Active Posts 6
- Profile Views 45
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
Focus 1.8 zetec
UK/Ireland Location
Suffolk
0
Neutral
User Tools
Friends
paulinsuffolk hasn't added any friends yet.
Latest Visitors
In Topic: Clicking Battery Saver Relay
10 February 2013 - 02:31 PM
Last year when this first started i checked the 3-pin socket and readings were fine at the time, giving the correct voltage... as you say it could be damaged after the work they've done.. and those wires 'can' break further up that little loom. I'll try another check when it's a bit warmer.! I swapped the relay with another but it still gave the same problem... stops when you give the alternator load though, like heated windows. Strange one this... but apparently not un-common.
10 February 2013 - 01:39 PM
I've just checked the battery and it's a Motorcraft Superstart, which i understand is the correct battery fitted by Ford.. it also has the 'Ca' marking on it which in the handbook means silver/calcium. This morning in the cold and without charge from running.. it's 12.7v.
Like i say, i'm going back to the original garage as they need to be given 1st chance to offer a repair (not trying to fix it myself, just want to be armed with enough info as possible) if they cant diagnose a fault then yes it will go to Ford main dealers for a fault code reading and repair.
After all this It still doesnt explain the battery saver relay clicking and the other probs... only that when you search the net for Focus RTX alternators.. they replies and feedback for that manufacturer are terrible along with ''do not buy''.. lol.!
10 February 2013 - 10:55 AM
Wouldnt the diodes in the alternator (after converting from A/C to D/C) effectivly block any power coming back and so only allowing the power to feed one way.. and when the battery has enough power, the regulator (beit smart charge or alternator controled).. back off the charge from the alternator.
Either way.. this battery was fitted to the car when we bought it, we've now done in excess of 20k miles on that battery and original alternator before the bearings went.. the problems started when replacement alternators were fitted.
PS . The lastest... last night both dip beams blew and the ABS light came on and the speedo/rev needles went crazy.! Really could do with a electics tech/wizard.. is there one here on this forum.?
09 February 2013 - 09:01 PM
if the wron g battery is fitted it will fry the alternator
How would it do that Arthur .. wouldnt the smart charge system pick that up and regulate charge to the battery and not cook the alternator.
09 February 2013 - 01:20 PM
Is a silver calcium battery fitted?
Not too sure.. but it is the same one thats been fitted and worked 100% perfect for the last 20k miles with the original alternator.. and the 1st replacement alt.. the only thing thats changed is those alterntors
- Privacy Policy
Find content
Latest Comments
More
