sgstanding
Member Since 12 Feb 2013
Offline Last Active May 19 2013 12:05 AM
In Topic: No Strength In Window Wipers, Headlights(Earth Connection?)
16 May 2013 - 10:28 AM
That's what I did when it snapped, new bolt, washers and scrubbed the connector with a wire brush.
The only thing that I can think of is where I've attached it back on to isn't meant for an earth connection, although it looks exactly the same and shouldn't make a differene as long as it's connected to the body? If that's correct..
In Topic: 2003 Intercooler Cover Fixings
17 February 2013 - 01:53 PM
Thanks guys.
Turns out it's an M4 screw with a brass threaded insert into the actualy intercooler plastic. The threaded inserts have actually been ripped out, with one unusable. So will have to use a self tapping screw like you said.
