nazsky786
Member Since 17 Feb 2013
Online Last Active Today, 12:08 AM
#401643 Mk2 Xenon Headlamp Retrofit
Posted by nazsky786 on 25 August 2014 - 09:07 PM
Replace the bulbs. For the same. Some say that changing bulbs for diffrent can cause issue.
#396828 Water In Boot
Posted by nazsky786 on 12 August 2014 - 07:49 PM
Ok. So that prob why there is do much water. Boot out of light and the focus has a common problem. I will try that tomorrow also. Just need to stop water getting in. I'm worried that I might mess up the sub or I get a major rust issue.
Sent from my HTC One_M8 using Ford OC mobile app
#396765 Water In Boot
Posted by nazsky786 on 12 August 2014 - 05:29 PM
I open the boot today to see loads of water and I mean loads. I have like a litre of water in the boot. You can see water drops on the subwoofer, and on the parcel shelf . I was hit in the back by a f****** stupid !Removed!. I've got issues not of water in boot and the dash saying boot is open till u open it and close it abit more. The repair shop has said the boot lid looks ok but it don't feel in line when you run your fingers in the grooves. Is this a sign that my car is twisted and it's time to let it go?
The guy hit the car while it was stationary which is the worse. And he won't pay for it . He's hide his car so I carnt get his reg . And police don't care. He my neighbour as well.
Can anyone help I a temporary fix or is it best to sell the car?
#392955 Not Starting. Immobiliser?
Posted by nazsky786 on 01 August 2014 - 10:41 PM
If you had a accident in the car, most likely the fuel pump would have been shutdown. To start it again the the a hole in the driver side kick panel closest to the door. Inside that hole is a red button push it and then try by first priming. Check this switch if it's not that then we need to do further checks.
#374510 Urgent Help.
Posted by nazsky786 on 14 June 2014 - 01:03 PM
Hello, The seat belts are long enough to secure a child seat. I know because I did take my niece out somewhere.
Are you 100% you installed it correctly. Use the seat belts on the rear closes to the doors don't use the centre.
#374081 Mk2 Xenon Headlamp Retrofit
Posted by nazsky786 on 12 June 2014 - 10:50 PM
I havnt even plugged in the sensors yet. Havnt even made holes for washers but it looked so good. Lights going up and down.
#374079 Mk2 Xenon Headlamp Retrofit
Posted by nazsky786 on 12 June 2014 - 10:49 PM
I just noticed my headlights going up and down .
#373421 Zetec Double Spoke Alloys
Posted by nazsky786 on 10 June 2014 - 07:47 PM
Spray the cap as well and choose between Matt or gloss but should look good.
#372203 Instrument Cluster Questions
Posted by nazsky786 on 07 June 2014 - 01:51 PM
Might just be the charger not working. Check to make sure you checked the correct fuse. Most chargers have a fuse within themselves as well.
#372002 Led Lighting Mod.
Posted by nazsky786 on 06 June 2014 - 08:16 PM
Led look way better. El look abit , well rubbish compared to led.
#371832 Led Lighting Mod.
Posted by nazsky786 on 06 June 2014 - 04:13 PM
I need some help with this mod, I'm thinking I will have to tap into the driver foot well light.
I want to put led light strips on the side skirts. So when you lock and unlock doors the side skirts will light up.
I think this would make the car look so good at night.
And light up when in reverse so helps see curb at night to stop alloy scratching.
Any tips will help.
#371187 Water!!!!!!!!!!!!!!!!!!!!!!!!!!!!help!!!!!!!!!!!!!
Posted by nazsky786 on 04 June 2014 - 03:41 PM
You can get a new cover from Ford or search a scrappy. On mk1 I think there is a seal which you need to change as the old seal should never be used again. But sound like the cover a seal are just there doing nothing. So I would replace them but get a new seal not one from scrappy.
#367945 Major Issue.
Posted by nazsky786 on 25 May 2014 - 09:41 PM
It's here. http://www.focusclub...hteraf inbouwen
#365318 Major Issue.
Posted by nazsky786 on 18 May 2014 - 11:43 AM
Ford already tried that. They disconnected battery. Tried using there diagnostics and all the come up was the GEM not responding. They even tried connecting my old gem and old cluster that didn't work. Tried copying my setting from old gem and putting it on new one that didn't work. Ford are lost on what the problem is. The gem having issues makes the airbag module have issues. Ford sent sure if there is a fuse to the gem itself. They printed a gem wiring diagram for me. So I'm going to check all the cables are connected fuses etc. Wish me luck.
#365181 Generic Electronic Module
Posted by nazsky786 on 17 May 2014 - 08:23 PM
Its actually model specific. You can take the GEM from one focus and move to another.
The program is only required if you take the GEM lets say from a LX Focus and move to a Titanium. As certain features are turned off.
That's why if you have a LX you place a Titanium GEM in you unlock features you would have never had before.
Programming is just a list of features that are meant to be on or off, that's how the Elmconfig cable works.
This thread may be old but just needed to clarify what actually happens. You can put replace a GEM best idea is to replace with a car with more spec or same as yours not one that is lower spec or you may lose features and then you will need the program to enable them.
