beatcon
Member Since 18 Feb 2013
Offline Last Active Mar 21 2013 11:28 AM
In Topic: Fix Durashift Gearbox Problem Easy.
21 March 2013 - 11:15 AM
ok need some advice i took the gesr shift actuator out there it moves freely.....seems to be fine. I put it back in and all was still the same. i noticed that the thing that was stopping the gears selecting is actually the little gear selector arm that clips into the plastic ball joint of the actuator rod. I disconnected the ball joint and the whole actuator mechanism seems to actually work it moves up and down as it should looking for the gears.
Could this be the clutch or gears that are the problem rather than the actuators.
18 February 2013 - 11:49 AM
hi i know i may sound totally daft but which bolts actually hold the gearshift actuator in place????? :unsure:
