Eddie777
Member Since 18 Feb 2013
Offline Last Active Apr 07 2013 08:47 AM
In Topic: Mondeo Mk3 1.8 Burning Oil
31 March 2013 - 05:02 PM
Did you resolve this?
Mine`s behaving the same.
In Topic: Mk3 1.8 Zetec Engine In Need Of Tlc
26 February 2013 - 08:12 PM
think P0400 is egr valve code.i would do a compression check.depending what the oil is like if its black or not i mean mine on 208,000 miles and still going,but read the piston rings on the 1.8 was of a cheap brand.dose it smoke on startup or if you in gear n go down a hill in gear with foot off throttle then at bottom of hill hit the throttle dose it puff blue smoke??i treated mine to a wyns engine flush last oil change
I will try the down hill suggestion. Not seen that before.
Are you talking of engine braking, and then floor it?
In Topic: Forum Newbee, Mondeo Mk3 Engine Query
22 February 2013 - 08:49 PM
Thankyou all
18 February 2013 - 03:30 PM
Yes, that's the best way to determine if it is a tyre
Thanks.
Thats something I can try.
18 February 2013 - 03:21 PM
Hello and welcome to the forum,
Is it an engine related noise?
Out of shape tyres can produce a humming noise like a worn wheel bearing.
Many thanks for your reply.
Will swopping the wheels front to back help me?
